steam problems
13 Aug 2011
This maybe the wrong place to post this, if so I apologies.
I'm having problems with playing games with a wireless xbox controller in steam.
When I load a game and start to play steam will interrupt trying to load or install another game and this is happening every 30 seconds or so.
I have tried to find threads related to this topic to no avail.
I have also tried to log onto the steam tech support but it wont except my user name and password.
Has anyone got any ideas how to sort this problem?
Sounds odd, do the games work without the controller connected?
Also the steam support site needs a new ID its not your normal steam login (as it tells you if you read it :p)
Does it just minimise the game window or completely shut it down?
When you say it tries to install something is there a box or window indicating what is trying to be installed?
Do you use Bitdefender Anti Virus?
Yes the games do work without a pad.
Yes it does just minmise the game window (which is enough to crash some games but not all).
Yes it comes up with the steam install or play box of various games.
No I do not use Bitdefender Anti Virus.
