SteelSeries 650 Headset
Suspended
18 Oct 2002
Thinking about ordering one, but worried about some 2015 comments about the mic not working. Anyone have one the bought this year? Any issues?
If not that, then what to go for? Have some good headphones (Beyerdynamics) so really only need a standalone USB mic - so suggest one of those if that's a better way to go.
Ta.
If you are after a cheap option then go for the Modmic.
ANTLION Audio ModMic V4 @ £39.95 inc VAT https://www.overclockers.co.uk/antlion-audio-modmic-v4-sp-041-al.html
ModMic is the perfect way to turn your performance HiFi headphones into a fully fledged gaming headset.
Only £39.95 inc VAT.
ORDER NOW
If you needed USB then you could go for this::
Blue Microphones SNOWBALL - ALUMINIUM @ £64.99 inc VAT https://www.overclockers.co.uk/blue-microphones-snowball-aluminium-sp-003-be.html
Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture sound with detail unheard of before in a USB mic.
Only £64.99 inc VAT.
ORDER NOW
Been using them for quite a while now 7 months+, and they're great, very comfortable and have only heard good things about the mic.
But if you already have some good headphones, might be worth just getting a Mic.
