** STEELSERIES BUNDLE BOXES - WAS £109.99 - NOW £64.99 **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
This is a one off opportunity to save £45 on some pretty epic bundles.
The Steelseries Siberia Frost and Heat special edition headsets are a great option for gamers looking to stand out with glowing earcups and a great finish.
Both bundle boxes come with a QCK+ gaming surface and a matching Sensei RAW gaming mouse.
In all, a complete bundle for anyone looking for a great peripheral set, and with £45 off the previous price, its a no brainer.
Stock will be LIMITED on this offer so please don't delay.
We have some frost in stock that I have discounted already but the main order will be due to arrive tomorrow or Monday
SteelSeries Frost Blue - Bundle Box (90084) @ £64.99 inc VAT
Ever Looked through peripherals wishing they all matched? well with the new SteelSeries Frost Blue Bundle box your able to do just that, in this bundle your getting stylish pad, headset and mouse which are all popular sellers get a new setup at this discounted bundle price!
Specifications:-
Steelseries Sensei Gaming Mouse RAW
- Colour: White (glossy), Grey
- Sensor: Laser
- Resolution: 90-5670 dpi
- Sampling rate: 12.000 fps / 3.81 m / s
- Image processing: 10.8 megapixels / second
- Connection: USB (gold plated)
- USB Frequency: 125 - 1000 Hz
- USB data format: 16-bit
- Cable length: 2 m (rubber coated)
- Layout: two-handed operation
- Buttons: 7 (programmable)
- Adjustable lift-distance
- Lighting: blue (several modes, brightness and deactivated)
- Dimensions: 68.3 x 38.7 x 125.5 mm (W x H x D)
- Weight: 90 g
Steelseries Siberia V2 USB Gaming Headset
- Construction: closed
- Speaker Size: 50mm
- Frequency response: 10-28000 Hz
- Impedance: 32 Ohm
- SPL at 1,000 Hz: 112 dB
Microphone:
- Frequency response: 50 - 16.000 Hz
- Sensitivity: -38 dB
- Pick up pattern: Unidirectional
- Color: Frost Blue
- Cable length: 3 m
- Connection: USB
- Plug: 3.5 mm
SteelSeries Qck+ Blue
- Material: Fabric (playing surface), foam (base)
- Color: blue, white (Frost Blue)
- Dimensions: 320 x 2 x 270 mm (W x H x D)
Was £109.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
SteelSeries Heat Orange Bundle Box (66002) @ £64.99 inc VAT
Ever Looked through peripherals wishing they all matched? well with the new SteelSeries Heat Orange Bundle box your able to do just that, in this bundle your getting stylish pad, headset and mouse
Specifications:-
- Colour: Black & Orange
- Sensor: Laser
- Weight: 90 g
- Impedance: 32 Ohm
Microphone:
- Color: Heat Orange
- Cable length: 3 m
- Connection: USB
- Plug: 3.5 mm
- Color: Red & Orange
ORDER NOW
OK, so I have had information that they may be delayed until mid way through next week.
Price will remain the same though :)
I have absolutely no need for one of these as my current Steelseries kit is going strong
But as its such a good price I have ordered Heat Orange!
My other gear can be hot spares just in case ;)
