SteelSeries Engine settings?
17 Feb 2009
Leeds
I don't quite understand what the LED ON/LED OFF settings are here? Also, is CPI the same as DPI?
Basically coming from an old-ish DeathAdder (didn't use any software with it), how can I set my new Sensei Raw to be exactly the same sensitivity? I believe that was 1800 DPI when plugged in and no software installed/buttons pressed.
Thanks.
yes the cpi is the same
u have two dpi/cpi settings so choose a low value u like to use and a higher value u like to use and save.
im guessing led on is one setting led off is another.
i have just done this to my kinzu ive set mine at 800 cpi and 1600 cpi polling rate of 1000
