- 12 Feb 2009
- London
So after some advice on these forums i changed my mouse to a Steelseries Sensei Raw which im more than happy with. Problem is the software it comes with for some reason wont work.
Either at the end of installing it crashes my PC and then when I start back up if i try to open steelseries engine to edit the mouse settings it just gives a "Steelseries engine has stopped responding." and this also means i cannot uninstall it either so im forced to delete all files and search registry to get rid of it.
Or after getting it to install properly once the software would not pick up that any steelseries products are connected so wouldnt go past 1st screen.
Ive tried many different sockets and reinstalled drivers and updated firmware on mouse.
It seems a pretty common problem but cannot find a fix.
Full system spec:
2500k @ 4.4Ghz
16GB DDR3
Asrock Z77E-ITX
Adata 120GB SSD
Dell U2410
Win7 ultimate 64 Fully up to date.
Logitech K750i Keyboard
Full system spec:
2500k @ 4.4Ghz
16GB DDR3
Asrock Z77E-ITX
Adata 120GB SSD
Dell U2410
