Hi Guys
Tomorrow I'm planning on buying a new keyboard, I'm not after any LEDS (had a QPAD MK85 before) or something special, I been using a bog standard £10 KB for a couple months and all i need is a basic mechanical KB.
Out of these 2 what should i go for? Or any alternatives
http://www.overclockers.co.uk/showproduct.php?prodid=KB-005-CM&groupid=702&catid=23&subcat=2107
http://www.overclockers.co.uk/showproduct.php?prodid=KB-026-ST&groupid=702&catid=23&subcat=2107
The steelseries is in stock in a local shop so i could pick it up tomorrow or go for the CM Storm. (If OcUK does a price match on the CM storm which I'm sure they will
Max budget £64
Thanks!
)Max budget £64
Thanks!
