SteelSeries Promotion!
Over the next few weeks we will be launching some great promotions in conjunction with SteelSeries. We start the promotion offering a FREE hardcase with any SteelSeries 9H Gaming Headset from now until 6.03.2014 which the second promotion will kick in!
Keep in the loop here: http://www.overclockers.co.uk/LP/steelseries_promo.php
SteelSeries 9H Gaming Headset USB - Black (61101) @ £149.99 inc VAT
Building on the historic SteelSeries audio tradition, a custom-engineered soundscape features a wide dynamic range, which makes it possible for 9H to deliver a balanced and linear tournament-grade advantage.
Powerful, detailed audio experience via tournament grade, next generation SteelSeries audio drivers that feature a wide dynamic range that allows you to hear all levels of your audio: lows, mids, and highs. Our audio engineers custom-engineered the soundscape for the best possible gaming experience. Advanced components like high grade mylar film to further perfect the sound with added clarity and no distortion.
The SteelSeries 9H when used with the included advanced USB soundcard features two Dolby® technologies. Dolby Headphone allows up to 7.1 channels of realistic multi-channel surround sound. Dolby Prologic IIx can convert a simple stereo signal into a rich, surround sound experience. In addition, it can convert a true 5.1 signal in a full 7.1 surround experience allowing for multiple listening modes and a more realistic sound.
When the SteelSeries 9H headset is plugged into its advanced USB sound card, it enables a noise cancellation microphone. When you’re playing multiplayer, it’s more than just skill that will win you achievements, it’s communication that will help you dominate. To support that, the 9H headset features an active noise-cancelling, “smart” microphone that allows your team to hear you above whatever is happening in the area around you – appliances, dogs barking, whining spouses, and more.
Headphones
- Frequency response: 10 – 28000 Hz
- Impedance: 32 Ohm
- SPL@ 1kHz, 1 Vrms: 110 dB
- Cable length: 1.2 + 2 = 3.2m
- Jacks: 2 x 3.5mm for PC
- + 4-pole 3.5mm Mac®, Mobile and Tablets
Microphone
- Frequency response: 50 – 16000 Hz
- Pick up pattern: Uni-directional
- Sensitivity: -37 +/- 3 dB
- Impedance: 2K Ohm
With a Free Steel series Hard Case
Only £149.99 inc VAT.
ORDER NOW
Headphones
- Impedance: 32 Ohm
Microphone
- Impedance: 2K Ohm
ORDER NOW
