Steelseries Rival 2016
Permabanned
8 Jan 2010
UK
Steelseries Rival 700
Looks like they are releasing a new mouse
https://www.facebook.com/SteelSerie...1451944176./10153469411854022/?type=3&theater
Wouldnt touch another after using the DA chroma... Not saying they are poo but for small hands they are horrible to hold :(
Thanks, but no thanks.
Just cause someone hasn't done it before doesn't mean it's a good idea.
Looks like a nice mouse although the little display is probably going to mean it's stupidly expensive.
It looks like a cool concept, dont think I've ever seen a mouse where you could swap cable or even the top cover. I won't 've getting it though, I bet it will cost an arm and I don't like big mice anyway.
Not for me, gimmicks, weight will be too high. The only good thing is seeing that sensor in other mice. Now for someone to release something simple and light.
Owned a previous Rival which was awful, the material used for the side grips just disentegrates after light use, not sure if they have updated that material used in later models tho.
Perfectly happy with my Zowie
Yeah they changed that after the early models did that. All the new ones are the more durable sides. Have had one for over a year and the grips just look brand new.
ahh so you did
and yes they did change the rival thumb bit, I believe they are offering replacements to people with that problem though. from the looks of their FB page.
Mine has failed but i got it free so no returns :D
