** STEELSERIES RIVAL + FREE QCK HEAVY SURFACE **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
This deal proved popular a few months ago so I have managed to do it again.
Put simply, this is one of the best mouse combos you can use.
I moved from a Mamba and hard surface over to a Rival and QCKheavy a while back and havent looked back.
Brilliant mouse, brilliant surface.
The QCK Heavy is usually £21.95 and our best selling gaming surface after the OcUK Mega Mats which makes this bundle an absolute steal
SteelSeries Rival Optical 6500DPI Gaming Mouse - Black (62271) @ £49.99 inc VAT
We took a look at the landscape of high-performance mice and felt we could do a better job. So we did. The SteelSeries Rival’s performance reigns over the competition thanks to a cutting edge sensor, newly developed switches engineered by SteelSeries, and a suite of tweaks to give you the edge over your rivals.
Rival is incredibly customizable with 16.8 million color, 2-zone illumination, a 3D printable nameplate for individuality, and SteelSeries Engine 3 for finely-tuned performance adjustments.
Features:-
- Extremely many settings in infinitely many profiles on software
- Right-handed mouse
- Adjustable lighting with 16.7 million colors
Specification:-
- Dimensions: 70 x 10 x 133 mm (W x H x D)
- Weight: 128 g
- Color: Black
- Resolution: 50-6500 DPI
- Acceleration: 50 G
- Connection: USB
- Polling rate: 1000 Hz / 1 ms
- Cable length: 2 m (rubber)
- Buttons: 6
- Life: 30 million clicks
Only £49.99 inc VAT.
ORDER NOW
SteelSeries Rival Optical 6500DPI Gaming Mouse - White (62278) @ £49.99 inc VAT
Features:-
Specification:-
- Weight: 128 g
- Color: Black
- Connection: USB
- Buttons: 6
ORDER NOW
Steelseries QcK Heavy Gaming Mouse Pad (63008) @ £21.95 inc VAT
The QcK series is one of the most used mousepads amongst professional gaming teams.
The SteelSeries QcK-line of mouse pads are made of high quality cloth material, providing a precise and consistent glide. All mouse pads feature a specially designed non-slip rubber base which prevents the pads from sliding, no matter what surface the mouse pad is placed on. The mouse pads differ in dimensions and thickness, but not in precision, glide or quality. As some of the mouse pads are very large, we highly recommend measuring how much space you have on your desktop before ordering.
- Ideal for low sensitivity mouse settings
- Compatible with all mice
- Specially designed non-slip rubber base
- Heavy thickness eliminates uneven surfaces
- Dimensions: 450mm x 400mm x 6mm
Only £21.95 inc VAT.
FREE WITH STEELSERIES RIVAL MICE
ORDER NOW
