Steering wheel suggestions?
ajf
ajf
30 Oct 2006
Worcestershire, UK
Anyone recommend a steering wheel?
Two I had seen:
Thrustmaster RGT
Logic3 steering wheel - no model number?
Want something decent so happy to pay reasonable money.
Also how do the wheels attach - do they have desk clamps or suckers?
Thanks
Andrew
On a budget, Logitech Driving Force range is pretty good :) not sure what the current "active" product is though. if you want the best, logitech g25/27 are some great choices, planning on grabbing one soon to upgrade from my driving force pro :)
logitech ones tend to be clamps
Thanks.
Had a look for the Logitech one and can only find the PS3 compatible ones anywhere!
I assume this IS different to the PC one?
G27 looks good, but was thinking slightly lower price -upto £100.
Andrew
Thanks.
Andrew
PS3 one works with PC out of the box :)
A used G25 (they are EOL now) will go for <100
