Steering wheels
20 Feb 2009
Ashton-Under-Lyne
I have an old Logitech Wingman Force Feedback steering wheel, but it doesn't work on W7 unfortunately, so I need a new one. Don't want to spend much, so G25/27 are out of the picture. Anyone have any ideas on any good ones?
Thanks all :D
Well your not exactly spoilt for choice with OcUK's steering wheels atm
£39.99 Speedlink Carbon GT Racing Wheel with Pedals Which says it has Force vibration, but thats maybe not the same as Force Feedback.
or
£199.98 Logitech G27 Racing Wheel (which I thought was the pre-order price, but it says 10+ in stock)
Was thinking of linking another wheel on a manufacture's site but as they sell direct that would class as a competitor and thats not allowed
I guess you could Google "Logitech Driving Force™ GT" ;)
Had a google of the Logitech driving force GT, and it looks like it's a PS only version? I don't care about it being second hand, if someone knows of a good discontinued model, but I think about £60 is the max (although would much prefer it less), so even the GT is out of budget I think.
Logitech site says
PC-compatible software
You can download the latest software and make it compatible with your PC racing games.
Otherwise I wouldnt have suggested it ;)
Sounds like you might be in Ebay territory
