Ok I have a plan to upgrade my PC in a step by step process, as I can't afford to splash out on a complete system in one go (or more to the point the wife would kill me
) So I have come up with a plan that achieves this in steps.
Current Spec:
AMD Athlon 64 3200+ (Socket 754)
msi k8n neo2 platinum (nForce 3)
pc3200 1GB (2x512MB)
Leadtek 6800 GT 256MB (AGP)
Rough Target spec:
~Intel Core 2 DUO E6600
~EVGA nForce 680
~GeForce 8800 PCI-Express
~2 GB minumum maybe 4GB of high speed memory
The plan is to buy a Asrock 4CoreDual-VSTA and Intel Core 2 DUO E6600, use my current memory and AGP graphics card. Then at a later stage buy a Directx 10 card like a 8800. Then change the mobo and finally the memory. or maybe the memory first
So can anyone see any flaws in this plan? Like will the 8800 work in the Asrock? whats the fastest speed memmory the Asrock will take?
) So I have come up with a plan that achieves this in steps.Current Spec:
Rough Target spec:
~EVGA nForce 680
