- 8 Sep 2005
- Chichester
Recently got a sony mex-bt5000 cheap, mainly for the bluetooth streaming and mobile hands free function. But after swapping the headunits over im noticing some weird problems. I can no longer unlock the car using the remote fob (although i can if its less than about 5minutes). So i have to unlock with the key, open the door, alarm goes off, and then i can disable the alarm using the fob. The stereo and car digital display reset every time i turn the engine off also. Have been told i might need a phantom power adapter? Any ideas?
