- 8 Jan 2003
- Scotland
I have a 2009 Mondeo Titanium X Sport. t came fitted with the Sony 6 CD DAB head unit and also Bluetooth + Voice Control.
A few weeks ago I upgraded the Bluetooth module to one that can also handle USB. To fit this I bought the cable from the module to the glove box, the bezel for fitting in the glove box and a USB socket for pairing the USB cable to the bezel. All of these were genuine Ford parts.
This all worked fine with my Sony unit.
Last weekend I removed the Sony unit and retrofitted the NX Sat Nav unit. Other than having to replace the surround fascia, the support cage and add a GPS mouse antenna, it was a matter of plugging all the connectors from the Sony into the NX unit. I had to leave the DAB aerial connection loose as the NX doesn't have DAB.
Now when using the USB socket (I have an 8Gb memory stick plugged into it), I get what sounds like alternator whine. It increases when I accelerate. It's not mega loud but it is noticeable when you turn the volume up, which I have to do as the USB volume is considerably lower than the radio.
Looking online, it appears I might need a ground loop isolator. However I don't know where to get one for USB and where it fits. A friend also asked if I earthed the head unit but there was no "earth" to speak of as such, I connected all the connections (other than the DAB aerial) that were connected to the Sony.
Would something like this worK? http://hifimediy.com/usb-isolator
