sterro advice
31 Dec 2002
on my PC
i got £250 to spend on a sterro
so what one?
but i was also thinking that i could put a pc in my car with a touch screen for £260, what option should i take?
your advice would be great, good and bad points.
thanks lads.
do you drive around and pull up in random carparks and sit in the car for a long time?
if no then dont get a carpc install, you just wont use it.
£250 will get you a nice stereo, some good dvd mp3 ones available on ebay for about that price.
Do you have decent speakers to play the decent sound the new HU will be getting, or will those come later?
i do, do a lot of driving. n was thinking about putting gps on it ect but i dunno if it would get nicked so fast.
may just get a sterro i dunno.
Car pc with touch screen for £260, don't think it can be done proper for that price if at all.
I would stick with a normal head unit.
Oh and its Stereo.....
yea it can.. got a broken 2ghz lap top that is broken screen wise. and 8" tft touch screen 180. gps £50
not 2 sad..
