Hi,
I've recently bought 2 x XL2420Ts and a 3D Vision 2 kit as part of an upgrade to eventually have 3 of these monitors in a surround setup. At the moment, I'm using them with my Dell U2410.
I'm now wondering whether I've made the wrong decision because while Eyefinity can look impressive, it seems to be so fiddly having to patch games and make constant adjustments to get things working. Also the stretched side screens seem odd, I know it's supposed to be a perception thing, but I ultimately wanted to end up with 3 x 3D which seems pointless if looking at the side screens shows stretched images. The missing text and menu problems in games is also frustrating.
The other problem is they take up my entire desk because of the size of the stands and depths of the monitors. I know I could help this by getting a triple monitor stand, but with the XFX one being £300 it would mean that the total cost for the monitors would be getting near to £1200 and I could get a 27" screen and a GTX 680 (which is my next upgrade) for that.
I think I've got three options....
1. Keep the BenQs, get a third one, stick with Eyefinity and hope things get better.
2. Keep just one of the BenQs and use this on its own for 120Hz and 3D and put the rest of the money towards a graphics card upgrade.
3. Change both BenQs for one 27" monitor, preferably the Asus VG278H which would work out cheaper than the two BenQs and the 3D Vision 2 kit cost.
Does anyone have any suggestions on what they'd do? I like the idea of having a bigger screen as I've had 24" for a while with the U2410, but would like 120Hz and 3D and would like to have a 3D Vision 2 monitor because my next upgrade will be changing my 5870 to a GTX 680.
I sit about 2.5 to 3 feet away from the screen if it makes a difference with a 27" 1080p screen.
Also, does anyone know why the 27" 3D Vision 2 monitors have disappeared from OcUK? I know the VG278H had a backlight problem, but I would've thought that would be fixed now....
Thanks!
Thanks!
