As above for some reason my flow meter has started sticking, only for a second. Also just before this started to happen the pump would not spin up straight away it took a couple of seconds.
I was told this might be due to under volting to the pump as I have connected to the fan pwm hub.
Any suggestions would be great,
Oh and I have flushed the whole system and the same.
) that you can feel the vibration of it spinning if you put a hand on it. It's also got a tacho connection (like a fan) so a dedicated header will be able to report back the rpm. Both these should let you be sure whether the pump is stalling or whether the flow meter is sticking or misreporting. Smffy's right though, the model of flow meter would be useful as for example, Aqua Computer's High Flow pump is a spinning impeller that could, theoretically get jammed (especially if not flat) but their MPS flow meters are differential pressure so there isn't anything moving to get stuck - although it could get blocked potentially.
It could be sticking but if you've already replaced it that would seem unlikely...although far from impossible. How long does it stop for? Does the pump keep buzzing during that time or can you feel it vibrating?
