Sticky adhesive for monitor screen / bezel?
8 Jan 2009
North East
I posted a question in the monitor section earlier with so far no replies: https://forums.overclockers.co.uk/showthread.php?t=18748168
Long story short, I bought a new Acer Predator 32 monitor (not from Overclockers), I don't want to replace it if possible in fear of getting a worse one back, only issue with this monitor is a gap towards the lower right of the monitor between the bezel and screen. If I gently push the bezel towards the screen the gap is gone and looks normal until I remove my finger and the gap comes back.
Anyway I had some ideas of maybe sliding in a little strip of adhesive strip or something similar etc to hold it in place but I have my reservations before doing so.
Is there a specific type of adhesive strip to use for this kind of thing? Would doing so be safe if it is even possible to manage to slide the adhesive strip in. Or should I just leave it alone? It kind of bugs me now I know it is there and with it been a noticeable gap I can only imagine there will inevitably be a dust build up so yeah it kind of bugs me.
Thoughts please :)
I don't think I would attempt to put tape in the gap, I have opened a few screens and most of the time it's either screws or just plastic clips, you could possibly use a very small strip of tape from the from to the back to pull it in but not sure how this would look
