Sticky Tape Residual
27 Aug 2005
Hi Gents
Currently in the process of removing the personalised plate of my vehicle which has left some sticky residual tape, what is the best way to remove this that also won't damage the paint? I've read about Isopropyl alcohol is probably best?
Auto Finesse obliTARate or Goo Gone. I’ve used them many times for removing number plate residue and when I removed the sound deadening from my E46 M3.
Someone used a vinyl plate on a car I recently bought and peeling the plate off left the entire sticky back residue on the bumper. I used AF product to get that off, took a while though with the amount that was left on!
xylene or acetone are the daddy's for sticky residue - had to buy xylene@screwfix for (original formula) hammerite thinning a couple of years back, just don't breathe in.
not sure what they replaced acetone in nail varnish remover or tippex thinner with, but they are no longer hardcore.
