Sticky tape...
6 Oct 2007
Liverpool
... My UV light in my Tower keeps falling, av used sticky velcro and double sided stick tape and tried it in a number of places in the case to see if surface made a diffrence.
any sujestions can only fink ov now using cable ties.
cheers
More seriously, I've found that insulating tape tends to stay where it's put. You can get it in different colours, which might be relevant.
No more nails sticky pads. Use the temporary ones. I use them to stick 2 cathodes to the back of my monitor. Been on for roughly 8 months now. Or Hot Glue Gun.
Try some clear silicone from a DIY shop (the kind of stuff you put around sinks etc). It takes a while to dry but when it does it's like strong glue - but peels off easily if you need to. I use it to hold fans it (less vibration than screws) and even my watercooling rad :)
