Following on from this thread
I need more specifics please
I'll start with requirements
Currently - 720p playback from hard drive/network of mainly .mkv
In the future - 1080p playback from hard drive and optical
Internet browsing, general use etc.
No games (apart from maybe a bit of Mame and flash stuff)
My current TV is a toshiba 32wlt66 which has terrible problems with VGA pc connection as the massive thread on the avs forums shows.
I did try it last night via dvi-hdmi on my gaming machine which has a 8800Gt and it was fine when output was set to 1280x720, 60hz, overscan removed in forceware drivers (with hotfix).
I'm pretty much set on the Antec Fusion black case as it looks like it will match my amp.
I was considering the following:-
AMD AM2 Athlon 64 BE-2350 Brisbane Core, Dual Core 2.1GHz, 1mb Cache, Energy Eff'''' 45W Retail
Asus M2A-VM HDMI
2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-5400 CAS 4-4-4-12
I am a little concerned that the 690g graphics chipset will not provide enough video acceleration to handle the 1080p playback.
Will that cpu handle it on it's own? I am not confident even when overclocked.
The other option I considered was basing something on an overclocked e2180 cpu. Would this have the necessary grunt for cpu playback alone?
I am unsure on motherboard chipset as well. The G35 is too expensive. Do any of the others provide enough hardware video acceleration? Which chipsets overclock reasonably well. I liked the look of the Gigabyte GA-73PVM-S2H but then I read the nforce 630i chipset only uses single channel memory.
The other option is to add in a seperate video card. I read that the newer ATi's provide hardware avivo acceleration for more hd formats than nvidia's purevideo HD.
With this is mind I was considering a passively cooled 2400pro. Then I read this review
Has this issue been resolved yet or is it still the case of no post processing on the 2400 and I would need to go for the 2600?
Any other recommendations? The 8600gt has been mentioned to me but again, it's more than I want to spend.
If the conclusion is that I need the gfx card, what mobo's are the mest matx for intel and amd in terms of overclocking.
OS at the moment is up in the air. I am leaning towards vista as I prefer the media centre in that to MCE2005 (this will mainly be for my wife so she can record TV easily). I imagine most of the file based HD playback will be using haali splitter/coreAVC codec and WMP 11.
Asus M2A-VM HDMI
