Bit of advice required for the A3 again.
See previous thread:
http://forums.overclockers.co.uk/showthread.php?t=18544046
Basically I had oil pressure issues and noises coming from the engine, replaced cam shaft, gaskets and oil pump.
Since having the car back, I'm using a litre of oil every month so I took it back to the garage. They've inspected and found that the turbo is passing oil? I brought up the 3 month warranty that's placed on my invoices and attitudes changed, apparently they've not went near the turbo so it isn't there problem? Well....there wasn't any consumption issues before they started working on it!
They've also charged me for work twice. The first time the car was inspected they didn't find any issues with the oil pump. After I took it back, they've noted on the second invoice that there was damage to the oil pump, problems with it and that the car had oil starvation as a result...surely this would've shown up the first time round? They've not looked at it properly the first time despite stating they have.
Where do I go? Live and learn or is there something I can do about this? Typical garage in the sense that their attitudes are a bit bullish.
