Still undecided and a memory question :(
3 Apr 2003
Guys i STILL have not ordered my replacement laptop as i just cant settle on a spec and a brand. I keep hearing mixed reviews of the dell laptops, i have specced up a nice Zepto laptop for around 735 with no OS though.
Basically speccing the similar specs the dell is a little cheaper but has an OS included. The downside is that the dell is 256Mb graphics instead of the 512Mb that the zepto has. But also that the dell has 667MHz memory wheras the Zepto has 800MHz which matches the CPU fsb. Does that make a difference however?
Also every basic spec for a gaming laptop seems to start with a 1.6 processor and i keep choosing the 2.0 upgrade, am i being silly? is it not required for playing games at mo?
Essentially i am looking to spend between 600-750 on a laptop to be used primarily for games, not interested in mad resolutions, nor games like crysis. It needs to run warcraft well, with a view to moving to warhammer. Also to have a nice build quality to the laptop. If anyone can offer any input here i would really appreciate it as i seriously need to get the laptop ordered before end up spending the money on random stuff and doom myself to sharing pc with my g/f forever!!!
Thanks all.
with a laptop you have to bear in mind that its much harder to upgrade, the ram and hd can be easily swapped, the cpu can but usually requires a full strip down of the unit, graphics uh oh no chance. so i would go for the best graphics/cpu combo you can afford, Hewlett Packard/Compaq are knocking out some really good quality kit at the moment especially the DV series, also some of the newer acers are good spec for the money, laptops have never been so cheap as they are now so take the plunge. try and go for a T5xxx or T7xxx cpu rather than a T2xxx they're quite abit more powerfull, better cache/fsb etc
I just got a Zepto 3415W Gamer for a little over £790 with Core 2 Duo T7250 2Ghz 800Mhz FSB, 2GB DDR2 667, 160GB 7200rpm HDD and an 8600m GT 512MB. If you wouldn't mind getting one with the 120Gb 7200RPM you could get something like that. No OS still though.
How is it performing mate? can happily get the smaller HDD as dont need more than that. whats the machine look like? keep seeing different versions of it in pictures, u able to get any pics up?
Hows the build quality and noise from the unit?
