Stock AMD fan
12 Feb 2006
No[r]way
Hey. I got an AMD Athlon XP Barton 2600 (1921.321MHz, 3846.33 Bogomips).
I've seriously contemplated OC-ing it, but I only got a stock AMD fan. I'm wondering, will these things handle the extra heat or do I need a more "professional" fan?
(I can't afford water cooling)
depends on a few things. Best idea is check what temps you have now (idle and underload) if its not too high oc it a bit and recheck. You may be able to do it with the stock fan.
Post your current temps if your not sure.
An after market cooler is never a bad thing, though if you don't want to splash out on one, maybe try buying some arctic silver 5 heat paste and applying that instead of the stock paste. That will drop the temps quite a bit.
dablade@RazorBlade $ sensors
VCore 1: +1.66 V (min = +1.31 V, max = +1.97 V)
+3.3V: +3.33 V (min = +2.96 V, max = +3.63 V)
+5V: +4.81 V (min = +4.49 V, max = +5.51 V)
+12V: +11.73 V (min = +9.55 V, max = +14.41 V)
-12V (reserved):
-12.32 V (min = -0.00 V, max = -0.00 V)
-5V (reserved):
-5.17 V (min = -0.00 V, max = -0.00 V)
CPU Fan: 5232 RPM (min = -1 RPM, div = 2)
Chassis Fan:
0 RPM (min = -1 RPM, div = 2)
Power Fan: 0 RPM (min = -1 RPM, div = 2)
M/B Temp: +43°C (high = +80°C, hyst = +75°C)
CPU Temp (Intel):
+26°C (high = +80°C, hyst = +75°C)
Power Temp:
-0°C (high = +80°C, hyst = +75°C)
CPU Temp (AMD):
+25°C (high = +80°C, hyst = +75°C)
vid: +1.650 V (VRM Version 9.0)
alarms:
w83l785ts-i2c-1-2e
Adapter: SMBus nForce2 adapter at 5500
temp: +48°C (high = +110°C)
modo77: Is that safe to do?
Shiz: I got AS5, using it for a year now.
Another thing I'm wondering about is that sometimes, my computer starts like pulsating noise. I don't know whether the CPU fan, the GPU fan or the power supply is making it.
(What i mean is that, let's say "shhhhh" is the regular noise. It often starts going like "shhhSHHHshhhhSHHshhhSHHH", quite randomly. It quits after some time, or if I move the computer.
The power supply is a relatively new Fortron/Source 400W one. I don't think it's causing it.
I've tried to localise the sound by opening the case and listening, but it just didn't happen then.
