Anyone know which fan comes with the phenom 9500?
Is it this one?
http://www.frostytech.com/articleview.cfm?articleid=1962&page=1
Is it this one?
No it's a really **** aluminum thing, without heatpipes.
Yep.So they're using a worse HSF for the phenom range compared to the athlon x2 range?
Yep.
Bargain, even if it doesn't work out, you should be able to sell it on for a profit I would think.
Hmm, im able to source a second hand retail phenom 9500 + unused HSF for £89. You think thats worth it? I was going to use a cheap £35 uatx 690G motherboard to build a media centre pc for around £200. I was hoping i could just set the stock fan on low speed and forget about it, which in the case with the above HSF i linked would have been viable.
