ADDA specify (PDF datasheet here) these 25mm thick 120mm fans to move 72 cubic feet per minute (CFM) of air, when just hanging there in space. They'll shift rather less than that between them through the PC-V1000, because each fan only has a 0.095 inches of mercury (inHg) static pressure rating. ADDA's 38mm thick 120mm fans with the same motor achieve 0.135 inHg.
