Stomp stomp stomp!
  • Thread starter Thread starter Cob
  • Start date Start date
Cob
Cob
30 Jul 2006
Antrim town
Sirius B -100 2.1 Hours
BillytheImpaler -23,599 1.6 Weeks
Coming through!
Don't trust the stats Cob my boy. I'm chucking out WUs at 2.4-2.5K PPD :)
True you will eventually stomp me but should be a while yet :p
Maybe.
Tho I've another 5k due tomorrow morning.
I'll remind you again when the time is nigh.
I go away in about half an hour so this is my last post until Tuesday. Hopefully my machine wont fall over while I am away!
The parts from my old machine [4400+ etc] are going to a friend some time soon and I shall be getting it folding for the cause! Might be too little too late but I have a horrible habit of surprising people with sudden bursts of PPD :D
Still, you only got this close because I didn't fold for about 2 weeks!
I will make sure the cell is nice and tidy, just in case you drop by while I am away :(
Damn you! It would appear you are running more machines than I am. My PPD is stuck at around 2.2K and there is nowt I can do right now to increase that.
Oh well, at least I have given you a small battle before the inevitable :(
It's a Q6600 running at 'only' 3Ghz (my DS3 won't clock the quads over a 330mhz FSB. That will be fixed with a new mobo in the coming week or so).
And I'm running two copies of Ubuntu 7.04 in a pair of VMWare virtual machines on Vista x64, making a total of 4 linux SMP clients, one for each core.
But each frame is taking about 40-50% longer than it was with my e6600 at 3.6ghz (<30mins as opposed to <20 mins). Some of that difference can be attributed to the ~20% lower overclock, but it's still more than I'd hoped for. Vista isn't a contributing factor because I get the same times on x64 XP, tho VMWare Server v1.0.3 isn't yet fully optimised for Vista. Vista still isn't officially supported on the Server, tho the latest version of Workstation is fully supported and I'd expect the next release of Server to be tweaked a little.
So there's still plenty of tweaking left to be done, although I realise that I won't ever get double the production I was getting with the dual-core e6600.
Have you tried just two SMP clients that way you can get rid of the second VMware and it's losses.
Afterall SMP is made for four cores, and the second client should use up the extra 10% (and shair the 90%) that not utilised by just one client.
I'm sure you've tested this and in theory e6600 users can run two smp's so a Q6600 should run 4.
How about two linux/VM and a winSMP client?
Dropping to 3 clients drops all 4 cores to about 90%. It doesn't sound like much, but it's 40% of a core when you think about it. The three clients would crunch their WU's faster, but total output would be less than that crunched by four clients.
The best thing would be for VMWare to allocate more than two cores per VM. That way i could run only one VM and gain some performance. But sadly they only allow upto two cores per VM.
And myself and winSMP don't get on. I'm waiting for the next version before tearing out my hair again.
WinSMP on x64 is no different to x86.
It's just that some people (like myself) have had no luck with it at all.
And yip Ubuntu is stiil the way to go if you have the resources to run a x64 VM.
rincinDub said:
Anybody know if you can install vmware on Ubunto.
I thought it was the other way around: you install Ubunto on a virtual machine created using vmware.
ms9cw
