Stone effect tiles
Permabanned
8 Jan 2010
UK
Hi
I saw the tile below on Victoria Plumb but unfortunately they said that is something they don't stock and the image is for illustration purposes only. My Google skills have failed to find something that is the same colour or very similar.
Does anyone know where I can find something like this?
Thanks
Ive seen something very similar in a tile shop up here called CTD. They have a few shops around here but not sure if they are national or not? If they are then they usually have big showrooms so worth a visit.
CTD are massive. I know my uncle kills works there for a living
Which means i also get a cracking discount:D
They have a large warehouse at denton. round the back of sainsbury's and my petstop
Ah, thats good news for the OP then although CTD are expensive if you dont know a tiler who can get you some discount!
Retails prices can be. But then the product is often MUCH better than the DIY sheds in my experience.
But then again I'm well biased due to the discount I can get.
