- 27 Mar 2004
- Between Realities
Hi Guys, The 6800LE in my Sig below is dead. Died a horrible horrible death.
Both myself and my girlfriend are at fault ofcourse
I overclocked it, My girlfriend pulled the couch too close to the front outtake fan. So basically turned my PC into an easy bake oven. hehe.
I had to replace the PSU and the Graphics card. Most definately both had died during the confict. Not all bad I got a hyper modular out of it
ANYWAYS.
I'm now back using my old 5200 128mb GFX card (the humanity)
And need a stop gap card something that is going to put me on, But not cost a fortune. I only have a cheap monitor, 1027 by 768 MAX. So the card doesn't need to be singing and dancing.
I would like to beable to play oblivion, Because everyone is playing it and i'm feeling left out. I want to be immersed too!!!
So any help would be great. No Budget really.
My current specs are in my Sig if you ignore the GFX card
I have the Asrock Dual, So can run either a Pci-E Card or AGP card.
I have only 512mb RAM, So i'm guessing more RAM on the card will probably help me out.
ANYWAYS.
