Stopping F@H
4 Sep 2005
London
... for a couple of weeks ;)
Not to say that i made any difference to the Teams outcome, but i'm selling my Socket A rig soon... And it's soon to be replaced with a 3700 SD :)
What kind of increase in outcome would i see from this cpu then? :D
Thanks
Not sure what the new rig will do. You are excused from major slackiness if you are upgrading though ;)
Look forward to seeing the output from the new rig soon :)
Dunc
well if you can get some double gromacs work on there then you'll easily double the output - plus you'll have a LOT more cache which always helps and faster system bus/CPU speed which will help
so I'd guess at least double if not triple or more with the right work available :cool:
