Stopping students delete printers 10.2.8
5 May 2003
UK
Hi guys,
We have about 20 macs here but the students keep deleting the printers.
We'd like to stop them deleting printers, but still allow them to control the printer queue.
Any ideas?
Thanks.
ban them from using the computers for a week? Should help them to get the message! sorry not a technical answer I know..
Are you familiar with unix as you can lock the folder with that and the only way to delete it is if you have the password to that computer?
Using:
Code:
sudo chflags schg foldername
Thanks for the replies guys :)
I have no idea why they are deleting them, banning them all because 1 person is doing it doesn't seem fair either.
Justin, I know a little bit...
We use two accounts, Student with no login and Admin with an admin password.
How would that command work in conjuction with that setup? :)
I was thinking either do it this way, or make a batch file (or whatever the crazy macs use) to install the printers.
Then if they do get deleted they can just double click on this to reinstall them.
