stopping unwanted connections to router
  • Thread starter Thread starter Ish
  • Start date Start date
Ish
Ish
11 Jan 2006
West Midlands
Hi
An adsl router is set to give an i.p range of 192.168.1.200 to 192.168.1.209 and all these ip's a reserved by mac address in the router for certain pc's.
If someone comes along and plugs in their own pc/laptop and it's set to DHCP the router doesn't allocate them an i.p so this is fine.
How do we stop people who manually enter i.p details into their machine connecting to the router eg if someone manually sets the IP on their machine to 192.168.1.220 then they can connect to the router and surf the internet.
TIA
Can you not use access control and lock access down to mac address also?
Hi
TIA
If you mean in the router settings then I have used the only available setting is where you assign each IP to a specific PC by it's max address.
This doesn't stop people who manually set their IP though :(
Hi
The mac filter works on wired connections.
The router is actually connected to a 24 port switch from which there are about 20 network points spread out all over the building .
The only option the netgear router has is reserve an IP for a pc by it's max address. I have this set but it doesn't stop anyone who manually sets an IP address on their machine.
Duke's idea of using an unsual IP range looks like it could be worth a try.
You're mixing up MAC address filtering for the wireless interface with reserved DHCP leases (which use the network card's MAC address to give it the same IP each time).
There should be some option to set a firewall rule blocking everything but the IPs you allowe.
