Storage Case for minimum 8 HDDs
5 Jan 2003
Didcot, Oxfordshire
Looking to replace my fractal R5 case used for my home server. Getting some vibration from the 8x HDD held within the case.
Considering phanteks P600 or phanteks 719 both with extra HDD rails.
Any other cases i should consider.
Define XL? You're going to get vibration from that many HDDs and there's only so much you can do with that (the define cases dampen pretty well).
Just a thought. What I used to do in these situations is find a case that supports 5.25 drives and get anti-vibration mounts like these -
