Storage issue
PR.
PR.
29 Mar 2005
Bedford, England
Argh, found out yesterday I've managed to paint myself in to a corner...
Basically when we received the new servers a few months ago when I was setting them up I found that you couldn't boot from a drive of more than 2TB. No problem, I created two virtual disks (Dells terminology) one an 80Gb RAID5 for the OS and a 7TB RAID5 for the Data.
The server has since been setup with DPM2010 which has managed to consume almost the whole 7TB so I needed to add more.
I've added a new 2TB drive, but I can't expand the array to include it! Turns out if you have more than one Virtual Disk on a controller you cannot expand the disks.
Now I'm stuck. I can't lose the 7TB of data as it's taken months to build up!
I thought perhaps I could backup the 80Gb virtual disk, then:
Delete the 80Gb virtual disk
Expand the 7TB Virtual Disk to fill the space
Create an 80Gb partition in the unallocated space
Restore Windows 2008 R2 to it
Repair any boot errors and good to go!
BUT I can't because you can't BIOS boot from a drive larger than 2TB! I can switch it to UEFI but then you need to reinstall Windows 2008 R2 as it won't see the change except during the initial installation.
Don't suppose anyone else has found themselves in this situation and resolved it?
Most annoying is I have 13 other servers I've built and deployed all the with the same issue waiting to be a problem...
Which chassis are the servers? Depending on the servers' physical disk capacity you could add new, smaller disk(s), e.g. 73GB SAS, 250GB SATA for the OS and try your plan above. Would check the documentation for the RAID card too, but I think you are indeed stuck for expanding virtual disks if there's more than one on a group of physical disks.
First off; If you've got 8 disks or more, you really ought to be running RAID6. I wouldn't fancy the rebuild times with more than 8 disks on RAID5, especially if you're using larger / slower 7200rpm drives.
Although you have said it's backed up on 13 other servers, it's worth saying. ;)
Maybe a better way would be to:
Back up the 80GB partition.
Delete it.
Expand the 7TB array in the controller menu, wait for the rebuild to complete. Array is no longer seen as 'expanded'.
Remake the 80GB partition and install the OS back onto it.
End result:
9TB of space minus parity
OS was removed and reinstated
I've probably missed something...
The server in question is a PowerEdge T410, unfortunately it's maxed out with drives, so I can't add anymore. It's purely a server to store backup files so slow downs for RAID repairs isn't a major issue.
Wouldn't want to have the new 2TB drive as a single volume, if it fails it takes 2TBs of data with it.
I could blow away the 80Gb partition and reinstall, but the DPM install is on that drive, and was hoping to avoid the risk of trying to restore the DPM database and getting it to match the 100+ volumes it's got going!
