I suspect this is probably something very few know about, even those who own Ryzen 2### with 400 series Chipsets.
StoreMI, new with Ryzen 2 / 400 series Chipsets turns your slow mechanical HDD into SSD level performance by meshing your mass storage mechanical drive together with your SSD by intelligently moving the critical parts of the application that take a long time to load to the faster SSD.
You can have, or in fact the best way to do this is to have your OS installed on your mass storage mechanical drive.
StoreMI will treat the Mechanical drive and the SSD as one drive and automatically move the files around for the best possible performance.
Normally this is something that i would overlook, i would pigeon hole it as bloatware. But this adds actual value, its actually useful, and it works really well not just for convenience and performance but you also don't have to chose between which games to put on the fast drive and which on the slow drive, this just puts it all on this one virtual mass storage fast drive.
