Storing a helium tank
14 Nov 2012
Chesterfield
I've a 3/4 empty small helium tank in a box in the house. I need the cardboard but the mother-in-law is being stubborn and says it cannot be stored in the garage. :mad: One of those *I know everything ones*
Is it safe to leave in the garage on a slightly raised surface so it doesn't get the base wet when it rains?
I hardly think it's going to cause issues with the British weather we are having.
Storage
Balloon gas cylinders can rupture when heated in a fire.
Store them in a well-ventilated, non-smoking area, away from other flammable materials and sources of ignition or heat.
Store cylinders in an upright position and secure them to prevent toppling. Never turn your back on a free-standing cylinder. Cylinder safety stands, trolleys and wall straps are available for purchase from BOC.
Cylinders stored in the open should stand on a well drained, flat surface.
http://www.boconline.co.uk/en/sheq/...andling-and-storage/handling-and-storage.html
There's literally nothing dangerous about it at all. If it's going to get damaged to the point where the metal bursts then I hardly doubt this box of yours would stop that from happening.
There's no reason why it needs to be in a box.
Helium isn't flammable, it might burst if you literally stick a fire under it but that's about it.
To be honest, there was no doubt in my mind, but when you get questioned about it and you have no response, the internet tends to be a good source of knowledge.
It would appear, that still stands :D
As good a place as any, free with my house came a rusting camping gas cylinder (the type that is single use, and the cooker pierces the top). I am unsure of how to dispose of it, fire may be a bad idea.
If you have a local recycling centre, they'll take it. I think a B&Q or camping/hardware shop could take it too.
Leave it in her room with the valve slightly open. Await hilarity when she speaks in the morning.
