Hi,
Been sorting out my crossfire setup giving a spring clean and refit, and I'm having some odd quirks with performance.
Systems is Asus A8R32-MVP, AMD X2 socket 939 @ 2.75ghz, 4 GB memory (DDR), currently using XP32 (XP64 was having issues with HDDVD/Bluray player support etc). Using 2 x 3870XT 512MB with both crossfire links in place. Using 8.6 drivers.
Ran 3dMark 06 and there is a difference (albeit small) between crossfire being on and being off (9300-odd vs 10400-odd) so looks like crossfire is in fact engaging. SM3.0 figure went from 4000-ish to 5500-ish.
Using fraps, did a playback of a demo I recorded earlier on UT3. No crossfire - min 45, max 380, avg 67. Crossfire enabled - an extra frame or two increase on minumum, but thats it??? In fact max frames dropped a bit?
This is at 1920x1600, all settings on max with no vsync.
Tried Bioshock, saved game at opening section when floating in the water (first time you have manual control). Fraps showing 35 fps with no crossfire.....and .... 35 with it enabled? Again, same res with all settings on max, no vsync.
Next - the witcher. When in village/outdoor section in chapter one, generally doing 25 fps without crossfire - and again the same with it enabled? Max settings, no vsync etc. I even dropped the AA and AF settings way down and it had little effect on the frame rates...
...rather confused now. Whats causing this? I realise that the cpu may be holding things back but surely maxing out the AA/AF should show if this is a gpu or cpu limit.
Is there any GPU heavy benchmark apps/games I can use to see if any tweaks have an impact on base performance?
Was considering removing the two 3870's and fitting a single 4870, but I'm assuming that if my system is not coping with what it has it won't be any better with the 4870.
Hopeing its something simple - don't really want to have to splash out on a new crossfire board, cpu and DDR2/3 mem.
Any ideas?
This is at 1920x1600, all settings on max with no vsync.Tried Bioshock, saved game at opening section when floating in the water (first time you have manual control). Fraps showing 35 fps with no crossfire.....and .... 35 with it enabled? Again, same res with all settings on max, no vsync.
Any ideas?
