strange beep
6 Dec 2006
Hi im getting 1 long beep when my computer is under heavy load im wondering does anyone know what this could be ? a PSU problem ? here are my specs
GA-p35-DQ6 mobo
4 gigs of ocz 6400 ram
1 of BFG 8800GTX
1 Q6600
1 corsair 520 watt PSU
thx
Where does the beep come from ? The motherboard, GPU or maybe the PSU if that also beeps.
Have you checked the temperatures? If its happening at load it could be a warning something is getting a little too toasty. I should try running it with the side off to see if that makes any difference. You should then easily be able to tell where the heat is coming from and if all the fans are working properly.
PK!
