A while ago I put together a system with a DFI Ultra-D mb and Antec Neo power PSU, the system ran with zero issues for over a year. I later split the system and built another rig, one using the DFI board and a new Tagan PSU and another system using the Antec psu and a new Asrock Dual sata2 mb. Again these two systems ran faultlessly for over a year.
Just recently I decided to build a home server system using the DFI board and Antec psu, but after putting the system together agian both components refuse to work together, the mb just simply doesn’t power up
yet when I try either components with a different psu’s or mb’s they work perfectly!!
I usually don’t get stumped on pc problems to easily but this one really doesn’t make sense, I’m just not sure which item is at fault as both work fine when used with other components.
Any ideas chaps??
Cheers
Any ideas chaps??
Cheers
