Kinda weird problem, running an 805 in my Asus P5ND2-SLi Deluxe and performance at stock is fine although when I change the settings to OC it doesnt actually apply the settings :/
http://www.motherboards.org/imageview.html?i=/images/reviews/motherboards/1529_p4_7.jpg
The BIOS looks like that and I have it at 720 FSB which should run at 3.4ghz... it just *doesnt* If andone with this motherboard/similar BIOS could shed any light I would be grateful, cheers.
Not had an Intel for a while
and never had a 775 system so I'm not 100% sure if there are any extra settings that may need to be changed.
