Hi there,
Did a bit of searching before posting but couldn't find anything matching.
A laptop I've done a bit of work on in the past has a strange recurring problem, what it's turned on it gets as far as showing the mouse cursor and then hangs indefinitely. Nothing else on the screen.
To fix it first time round I booted in safe mode, removed Avast, rebooted and all good! Installed AVG and it was fine for about a year.
Now it's done the same thing again, twice in quick succession. If I safe mode, uninstall, reboot and reinstall its fine for bit (multiple restarts to test) then randomly crashes again. Something is obviously taking issue with the AV but I don't know where to start.
Spec:
Lenovo IdeaPad G560 Laptop
Pentium P6200 2.13GHz
500GB HDD
3GB RAM
Intel HD
Windows 7 Home Premium
I'm seeing it later and will follow the usual steps to rectify, just wondered if anyone else has seen this kind of weirdness before and has any tips?
Cheers.
Spec:
500GB HDD
3GB RAM
Intel HD
Cheers.
