Hey folks,
Recently received a new BT Home Hub 3. Had a Home Hub 2 prior to that which worked fine. Anyhow, it all works OK except for one machine via ethernet.
Let me explain ...
1. I can connect wireless via my laptop and surf the internet
2. I can connect the same laptop via ethernet and surf the internet
3. I can't surf the internet on my desktop PC via ethernet (although when I connected the laptop via ethernet I used the same ethernet cable and hub connection as the desktop PC so it proves that is OK)
The desktop PC gets an IP address from the hub and according to Windows 7 64-bit, the network is running OK and it can't find any problems. When I launch Internet Explorer, I can't load websites, or at least, it tries and it's almost as if the connection is mega slow and it struggles to display anything.
I have an 8 MEG connection and browsing/download is usually quick.
If I plug my Home Hub 2.0 back in, the desktop PC can browse the internet just fine via Ethernet.
I am running a Realtek PCIe Gigabit family controller and am pulling my hair out trying to find out why it works with the home hub 2.0 and not with 3.0.
BT have said there is a problem with my computer and I need to speak to a local PC expert I even, foolishly, installed a fresh copy of Windows 7 64-bit Ultimate, thinking that woulld sort it but I still have the same problem.
Any advice?
Let me explain ...
 I even, foolishly, installed a fresh copy of Windows 7 64-bit Ultimate, thinking that woulld sort it but I still have the same problem.Any advice?
