Strange but true...
18 Oct 2002
1. While sitting at your desk, lift your right foot off the floor and make
clockwise circles with it.
2. Now, while doing this, draw the number "6" in the air with your right
hand.
Your foot will change direction!!!
I told you so... And there is nothing you can do about it!
:eek: :eek: :eek: :eek:
As with all these little trials, it can be overcome by swiftly putting your head in the nearest toilet bowl and flushing.
I really can do it, just do it backwards. :)
its because your brain cannot differentiate between the two actions when both your foot and hand are doing two different things. If it was left hand and right foot, or right hand left foot you can do it.
I think i saw this on Brainiac "things John Tickle cant do!"
hand.
Just draw the six in the other direction. ;)
I can do it ??
Try clasping ** hands so your palms are facing you and spread out but your knuckles meet and fingers are clasped, and try turning your thumbs in opposite directions, not the same direction but at a different time... Now that's truly hard.
If you concentrate really hard you can do this, I did it after about 8 attempts :D I will see if my drumming bandmate chum can do this (infact you probably already have Jack ;) ).
