Strange CPU temp spikes
1 Feb 2012
While running OCCT my CPU is sitting at 34c but once in a while jumps up to 235c:eek:. It doesn't stay there just blips up then down maybe once every 30sec to 1min.
Also does the same thing again but down to 11c?
Is this a sign of things breaking down and need replaceing, or just a weird signal.
Thanks Mark.
Just a weird signal, probably just a bug with the software you are using to read it. What do you use?
Try coretemp, realtemp or hwmonitor
Just used Core temp and Speedfan and both are showing 34-35c. Then if you load up OCCT all 3 programs will spike up and down, so I guess it's just a OCCT bug.
