strange CPU temps problem
17 Aug 2008
Hi guys.
I done my first build recently and all went (mostly) well but im a bit concerned about my CPU temps.
core #0 and #1 are the same usually around 32 degrees but core #2 is always at least 10 degrees cooler, and core #3 is around 5 degrees cooler.
I know I shouldnt be complaining about it being too cool but such big differences makes me think there may be a problem?
using arctic cooling freezer 7 pro CPU cooler with pre-applied thermal paste with everything at stock.
heres a picture
anyone think this is a problem?
Personaly I would say they look to low, try Real Temp and HW Monitor to double check.
You do get different cores with different temps could be uneven heat spreader.
HW monitor reports the same mostly
#1 33
#2 33
#3 23
#4 25
realtemp is reporting
27
27
17
20
at idle
i tested the sensors using realtemp and they reported
#0 - 5
#1 - 5
#2 - 8
#3 - 9
See i thought they looked too low, thats why i posted, but could that be a bad indication of something?
