Howdy
grabbed myself a 9600GT yesterday to celebrate a new job, and so far I'm extremely impressed!
I ran the crysis built-in benchmarks to try and find a fps-sweet-spot, and found that with every consecutive run, the average fps dropped..
I can understand that the first run is slower as it's loading textures/sounds/everything, but why does the performance drop 2nd run>3rd run>4th run?
This is replicable, and happens in the gpu benchmarks aswell
PS: I know the fps there isn't playable, this is just an example grab from the timedemo logs
*edit* Here it is again, but WAY more extreme this time:
Code:
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
!TimeDemo Run 0 Finished.
Play Time: 82.10s, Average FPS: [COLOR="Red"]18.27[/COLOR]
Min FPS: 2.74 at frame 196, Max FPS: 31.20 at frame 111
Average Tri/Sec: 19228652, Tri/Frame: 1052465
Recorded/Played Tris ratio: 0.68
!TimeDemo Run 1 Finished.
Play Time: 69.48s, Average FPS: [COLOR="Red"]21.59[/COLOR]
Average Tri/Sec: 22753570, Tri/Frame: 1054017
!TimeDemo Run 2 Finished.
Play Time: 75.75s, Average FPS: [COLOR="Red"]19.80[/COLOR]
Average Tri/Sec: 20908946, Tri/Frame: 1055893
!TimeDemo Run 3 Finished.
Play Time: 94.39s, Average FPS: [COLOR="Red"]15.89[/COLOR]
Average Tri/Sec: 16750042, Tri/Frame: 1054028
TimeDemo Play Ended, (4 Runs Performed)
Code:
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
Play Time: 96.55s, Average FPS: 20.71
Min FPS: 12.32 at frame 258, Max FPS: 39.66 at frame 63
Average Tri/Sec: -21994952, Tri/Frame: -1061854
Recorded/Played Tris ratio: -0.86
Play Time: 100.08s, Average FPS: 19.98
Min FPS: 11.31 at frame 1955, Max FPS: 39.66 at frame 63
Average Tri/Sec: -21041566, Tri/Frame: -1052958
Recorded/Played Tris ratio: -0.87
Play Time: 170.70s, Average FPS: 11.72
Min FPS: 0.00 at frame 373, Max FPS: 39.66 at frame 63
Average Tri/Sec: -12333326, Tri/Frame: -1052623
Play Time: 301.22s, Average FPS: 6.64
Average Tri/Sec: -6999000, Tri/Frame: -1054129
