I have just upgraded to an E5200 which I have got overclocked to 3.6GHz at 1.2V.
My idle temps according to real temp are 50 degrees which seems far too high. I tried reseating the heatsink which had no effect and I get about the same idle temp if I lower the clock to 3GHz.
Load temps are about 66 degrees running intel burn test. This doesn't sound too bad at 3.6GHz from what I've read.
Do the temps sound right? Could my old P965 motherboard be a problem reading temps from a 45nm chip?
