- 29 Mar 2012
Hi, wondering if anyone has any thoughts on why a Corsair 3 pin fan has just started going at 100% all the time, from start-up, regardless of temps.
It's in a 2 week old OCUK build (Neon), which was completely silent at idle to start with. I wanted to add an SSD I had, which was a mistake as I can now see that the cable management/build quality is somewhat lacking.
Anyway, after successfully installing the SSD, the fan has run at 100% ever since. No more do I have a silent PC on idle
Is it possible I could have knocked something while fiddling with the cables? I would just have a look myself but because it is in such a state I'm worried I may make things worse (the reason for mentioning the bad physical build, not just for a dig at OCUK).
I wonder if for instance, could I have dislodged the 3 pin plug for the fan? Maybe that would just make it spin at 100% as it has no control from the system.
Any thoughts or insight before I don my Indiana Jones hat and open her up for a look would be much appreciated.
Temps are fine in HWMonitor btw.
Thanks in advance.
Thanks in advance.
