Strange fan speed problem
25 Nov 2007
London
got my q6600/ abit IP35 pro/ tuniq tower... anyway i checked bios looking around and fan speed was 1200rpm roughly, and using the fan control i see it go upto 2000rpm, as it is suppose too... however now on the max setting it is 1200rpm, and if i turn it down it goes towards around 600 or so..
i dont really care about noise so for me i want to get max speed out of this fan, ive tried to turn off any sort of speed control in bios.. turned it on and off while having the thing on max/min etc... doesnt seem to want to get back to 2000rpm...
any suggestions?
although ive overclocked it to 3 ghz, load temps were 33 and idle 23 using speedfan this is for the core0/1/2/3 readings. the one called "CPU" says it is 14 degrees so i assume that one is malfunction and the others are ok?
