- 24 Apr 2012
Hi, I'm having a tricky issue with my PC at the moment. It is suddenly failing to POST most of the time (~8 times in 10), with the VGA Q-LED remaining lit. If I keep trying, eventually it will succeed and boot Windows 11 with normal display output, but within a few seconds the monitors will go black and the system reboots back to a failed POST state. Weirdly, sometimes when it does boot Windows, it will boot with only a single monitor, and with the device "stopped (code 43)" in Device Manager:
In this state, display output is fine on the single monitor and the system seems stable, with an uptime of several hours rather than seconds and can browse/watch vids etc. If I install the Nvidia drivers, the other monitors start displaying an output, but the system instantly experiences a few lag instances before the displays go black and once again the PC reboots back to a failed VGA POST state.
Other info:
- No flickering/artifacts
- Both BIOS and HWInfo report +12v values between 12.172v - 12.268v
- GPU is now reported running at PCI-E x16 @ 1.1
- Will happily sit in BIOS/as above/Windows safe mode without any issue
- All temps fine
- No spare PSU/GPU to swap in and test
- Overclock settings removed
- GPU, RAM, power cables checked and reseated
Motherboard: Asus ROG strix x570-f
GPU: Asus TUF RTX 3070
PSU: Superflower leadex platinum 1000w
I wouldn't have expected a GPU to fail in this way? Any thoughts on this one appreciated, thanks!
Other info:
- All temps fine
